Academic Hardware Products (myDAQ, myRIO)
implement ping))) sensor on the myRIO
I'm trying to implement the PING))) sensor with the myRIO in labview.
In the robotics toolkit there are vi:s for implementing the PING))) sensor. The problem is I don't understand how these work.
First of all, I find these under robotics->Sense/Act->I/O with sim->Sonar->Parallax PING))). It is also possible to find the read PING))) under the starter kit menu. However, both these require an initialisation. And I don't know how to implement these and I can't find any help on the initialisation either.
Has anyone done this? How do I do it?
If it is not possible to implement it this way, how can I implement it manually? I found one solution online - however I couldn't open that properly which made it hard to understand.
Thanks!
(6,245 Views)
Hello izredam,
Can you share what your current code exactly looks like?
Which online solution did you find?
Is it this one?
https://decibel.ni.com/content/docs/DOC-30452
Why are you not able to open it succesfully?
Which messages do you get?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(6,222 Views)
