Academic Hardware Products (myDAQ, myRIO)
myDaq and iWorx sensor connection
Hi, Smiley Happy
I am a beginner in this field. I have problem.
I have mydaq and some iworx senors/probes   sensor like this   and this and others.
I use Biomdecal Workbench. When i connect iworx probes connecting to mydaq they not show audio ports only input 0/1.
I search in web not much information about this topic.
In the web is some topic mydaq and iworx probes with LabView?
(7,147 Views)
Are you also using this?
(7,140 Views)
no
(7,128 Views)
Hi keiko,
How are you viewing the inputs?  Are you using the test panels in Measurement and Automation Explorer (NIMAX)?  Do you see the dmm input as well as the ai0/ai1 in MAX?
David B
(7,114 Views)
Hi keiko,
It also doesn't look like there is a lot of info about using iWorx with the myDAQ.  Are you using the iWorx Data Plugin?  While there isn't a lot of information about using iWorx with myDAQ, you may be interested in more material about the myDAQ listed below:
Using NI myDAQ with NI ELVISmx Software Instruments
How to use LabVIEW Biomedical Toolkit – Biomedical Workbench
David B
(7,112 Views)
