01-03-2013 10:21 AM
Hi, ![]()
I am a beginner in this field. I have problem.
I have mydaq and some iworx senors/probes sensor like this and this and others.
I use Biomdecal Workbench. When i connect iworx probes connecting to mydaq they not show audio ports only input 0/1.
I search in web not much information about this topic.
In the web is some topic mydaq and iworx probes with LabView?
01-03-2013
11:07 AM
- last edited on
10-14-2024
09:06 AM
by
Content Cleaner
Are you also using this?
01-03-2013 04:59 PM
no
01-05-2013 10:53 AM
Hi keiko,
How are you viewing the inputs? Are you using the test panels in Measurement and Automation Explorer (NIMAX)? Do you see the dmm input as well as the ai0/ai1 in MAX?
David B
01-05-2013
11:04 AM
- last edited on
10-14-2024
09:11 AM
by
Content Cleaner
Hi keiko,
It also doesn't look like there is a lot of info about using iWorx with the myDAQ. Are you using the iWorx Data Plugin? While there isn't a lot of information about using iWorx with myDAQ, you may be interested in more material about the myDAQ listed below:
Using NI myDAQ with NI ELVISmx Software Instruments
How to use LabVIEW Biomedical Toolkit – Biomedical Workbench
David B
