Academic Hardware Products (myDAQ, myRIO)
myRIO change IP address
Hi all
anybody can tell me how to change Myrio IP address for NIarc 2014?
thanks
(10,095 Views)
Hey Jeff,
Have you gone into MAX and tried changing your IP Address from there? If you select the device under Remote Systems, you should be able to access the settings under the Network Settings tab near the bottom of the screen.
Douglas Choisnet
(10,071 Views)
This does not work! I can see what IP address myRio has, but can't change it
(9,611 Views)
Maybe it gets an IP automatically via DHCP. In order to set a fixed IP address, you need to disable that first.
(9,604 Views)
Thanks for the reply. 🙂
Where am I supposed to turn off DHCP? On the USB to LAN interface on my PC? (It is connected through USB
(9,579 Views)
When you have it connected through USB it’s just going to let you set it using DHCP. Why do you want to change it? If you connect it through Wifi you can set it to be static.
Connecting NI myRIO to a Host Computer (myRIO Module):
http://zone.ni.com/reference/en-XX/help/373925A-01/myriohelp/myrio_usb_wifi_config/
AGJ
(9,560 Views)
Ok thank you.
I basically wanted to change it because of a project I got that had a completely different IP address, and I wans't able to change it in the program for whatever reason.
I'll consider my problem solved. 🙂
Thank you both!
(9,545 Views)
