09-22-2014 06:04 AM
Hi all
anybody can tell me how to change Myrio IP address for NIarc 2014?
thanks
09-23-2014 10:35 AM
Hey Jeff,
Have you gone into MAX and tried changing your IP Address from there? If you select the device under Remote Systems, you should be able to access the settings under the Network Settings tab near the bottom of the screen.
01-23-2015 06:08 AM
This does not work! I can see what IP address myRio has, but can't change it
01-23-2015 11:15 AM
Maybe it gets an IP automatically via DHCP. In order to set a fixed IP address, you need to disable that first.
01-26-2015 04:40 AM
Thanks for the reply. 🙂
Where am I supposed to turn off DHCP? On the USB to LAN interface on my PC? (It is connected through USB
01-27-2015 12:39 PM
When you have it connected through USB it’s just going to let you set it using DHCP. Why do you want to change it? If you connect it through Wifi you can set it to be static.
Connecting NI myRIO to a Host Computer (myRIO Module):
http://zone.ni.com/reference/en-XX/help/373925A-01/myriohelp/myrio_usb_wifi_config/
AGJ
01-28-2015 07:50 AM
Ok thank you.
I basically wanted to change it because of a project I got that had a completely different IP address, and I wans't able to change it in the program for whatever reason.
I'll consider my problem solved. 🙂
Thank you both!
