Academic Hardware Products (myDAQ, myRIO)
myRIO data update
Dear sir,
I have a confusion in the VI that i have attached. I want to import the data i had got in myRIO. so i created a shared variable for voltage, current, power factor. When i run the excel VI the value of current is wrongly updated as ZERO in excel sheet.
The other doubt is, whenever i run the final VI the voltage and current values are continuously updated, when i stop the VI the values of power factor is updated. Initially i thought the reason behind this is the power factor is placed out of while loop.even when i removed the while loop the power factor value is displayed a zero and the same continuous continuous when i stopped the VI. I could not solve this problem sir, so i am seeking your help,please help me to rectify this error sir.
Message 1 of 8
(7,737 Views)
Hi swathik.
Can you attach a snap of your excel sheet as well?
Cheers,
Rao
Message 2 of 8
(7,701 Views)
i attached sir
Message 3 of 8
(7,689 Views)
i attached sir
Message 4 of 8
(7,688 Views)
Accepted by swathik
Hi Swathik,
The answer to your question as to why the power factor updates only once is because you have placed that indicator outside the while loop (as you mentioned). The solution is not to remove the while loop, but put all the code that you want to be updated/ repeated multiple times into one while loop,i.e.., if you want all the calculation of power factor and such parameters (P,Q,S,phi) to be also carried out every time and logged every time, put it inside the while loop.
Another thing, is the improper use of the shared variables. You have to be very careful in the implementation of the same.
It is a much better practice to go ahead with the Producer consumer architecture, which you can follow from the following link
https://www.ni.com/en/support/documentation/supplemental/21/producer-consumer-architecture-in-labvie...
The producer loop will keep generating values from the myRIO, and the consumer loop will log the obtained data into the excel sheet.
Cheers,
Rao
Message 5 of 8
(7,682 Views)
Please send me any links regarding shared variable sir.
Message 6 of 8
(7,655 Views)
i am running server VI and client VI using my RIO. i want to get the data in the web page with excel sheet.
here i attach my client and Server vi programs
Message 7 of 8
(6,100 Views)
Hi ,
Try using Network Published shared variables to transfer data between Client and Server. Should be much simpler to do this.
https://www.ni.com/en/support/documentation/supplemental/22/buffered-network-published-shared-variab...
Regards.
Message 8 of 8
(6,097 Views)
