Academic Hardware Products (myDAQ, myRIO)
pci 1710 driver
i have a problem with Advantech 1710 PCI card on Win XP. I have LabView 10.0. It doesn't recognise the card in MAX, but in device manager it does...
I ca't find the proper driver for it here http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/ps/20/sn/catnav:id,n2:A/scope/e...
or here http://support.advantech.com/support/DownloadSRDetail.aspx?SR_ID=1-O1VSR&Doc_Source=Download
Any idea?
Thanx to all!
BR,
Vojko
(6,446 Views)
It's not supposed to be recognized in MAX - it's not an NI device. The screen shot you posted shows that it is recognized by the Advantech software so you have the correct hardware driver installed. You will need to use Advantech VIs for programming.
(6,440 Views)
Thank you!
(6,433 Views)
