Academic Hardware Products (myDAQ, myRIO)
plot 4 components on a 3D Graph
Hi, i'm trying to plot a 3d graph with intensity values for each defined point (or area if needs be)
so each point has (x,y,z,i) values.
someone said on anther thread that this exsisits already in the 3d plot as the 'w' array, although i'm having trouble finding it.
has someone got an example of it being used?
Cheers
John P.
Message 1 of 11
(10,488 Views)
Hi John,
Are you using LabVIEW? If so what version? If you are using another programming environment please can you tell me what it is and what version you are using.
In LabVIEW 8.6 this should be relatively easy, but there is no real point telling you how to do this until I know what you are programming in as the 3D graphs were completely redeveloped in LabVIEW 8.6 and so any previous version will have a different method.
Regards
JamesC
NIUK and Ireland
It only takes a second to rate an answer 🙂
Message 2 of 11
(10,473 Views)
hey, i'm on lv 8.2, and i'm kinda stuck with it, we do have lv 8.4 availible if needed, so *in theroy* i have access to both versions.
I'm not useing any other enviroments.
Message 3 of 11
(10,458 Views)
Hi John,
Once you have placed down the 3D graph on the front panel, if you go to the block diagram and open the SubVI, you will see in the case structure to the right of the VI there is an invoke node called either  Plot3DSurface or Plot3DSimpleSurface depending on if you are using X Y & Z or just Z as an input, on these invoke nodes is a W array that accepts a 2D array of magnitude data.
This is the W array you are looking for.
Regards
JamesC
NIUK and Ireland
Message 4 of 11
(10,446 Views)
Hi, now that you say its all come flooding back to me.
i've used that before - i've added a picture to show where i've tracked it down with your instruction.
Although i've forgotten one thing, how to you add a fresh input to the subVI? or how else do you pull the data in to plot it?
John P.
Message 5 of 11
(10,444 Views)
I've made one from cropping the guts out of the surface image
and forming a new VI.
do you think this'll do it, I'm trying to make some data for it now.
John P.
Message 6 of 11
(10,442 Views)
It looks like you have the basic idea of this, however I think the W Array needs to be 2D. The help file can be found at C:\Program Files\National Instruments\Shared\MeasurementStudio\Help\cw3dgrph.chm
Regards
JamesC
NIUK and Ireland
Message 7 of 11
(10,439 Views)
dang, yup you right it does need to be 2d.
Message 8 of 11
(10,437 Views)
It this better?
-see attached.
Message 9 of 11
(10,436 Views)
Accepted by John Pierson
Give this a try, I have wired the W Array also into the true case with the simpleplot
Regards
JamesC
NIUK and Ireland
Message 10 of 11
(10,434 Views)
