Academic Hardware Products (myDAQ, myRIO)
when you install a program myrio error is displayed 2147220623
Error -2147220623 occurred at Property Node (arg 1) in Target_Connect.vi->CheckSoftwarePage.vi->CheckSoftwarePage.vi.ACBRProxyCaller.81500038
Possible reason(s):
NI System Configuration: (Hex 0x80040371) The property does not exist for this resource.
(6,438 Views)
displayed data window. please tell me how to install software in myrio?
(6,388 Views)
Hello VOYA1,
What kind of myRIO do you have? What version of the RIO driver are you using? I also found this Knowledge Base article that talks about his specific error you are seeing. It seems to hint that your firewall may be at fault in this scenario as the myRIO uses Ethernet over USB to install software.
http://digital.ni.com/public.nsf/allkb/81BBF63EFD85F43286257D8F00450C7D
Please try and disable your firewall to see if that resolves the issue.
John H.
Applications Engineering
(6,360 Views)
Resurrecting this thread since it was flagged to me concerned about the suggestion to disable the firewall.
In the past, I have had to disable firewalls to get two computers to talk to each other.  I have not needed to do that for a long time now (since Windows XP).  I have not needed to do anything to a firewall to talk to a myRIO, even with the corporate overkill firewalls.
The only place I would consider disabling a firewall would be on a computer on a small, private network with no possible connection to the outside world.  I am literally talking a test rack with only instruments on a network and not even connecting up to a company/home network.
GCentral
(4,227 Views)
