Academic Hardware Products (myDAQ, myRIO)
why does my ouput signal produce triangle waves when i want sine waves
in labview i use daq assistant to create a output voltage signal to create a sine wave. when i connect it to the opscilloscope it reads triangle waves. can someone please tell me why this is.
(7,585 Views)
try increasing the update rate...if it doesn't update but a few points per period it might look like a triangle...
what HW are you using?
(7,584 Views)
i am using ni cdaq9172
(7,582 Views)
when i run the test run it works fine but when i generate the code from the daq assistant thats when it produces the triangle waves.
(7,580 Views)
Accepted by reggie2016
9172 is a chassis so I would need to know the module you are using, too. You should try the example:
%PROGRAMFILES%\National Instruments\LabVIEW 2012\examples\DAQmx\Analog Output\Voltage - Continuous Output.vi
It shows you how to create a waveform to generate, you could use that piece and feed it into your daq assistant.
(7,577 Views)
