Academic Hardware Products (myDAQ, myRIO)
why the fgen output so small(0~10mv)
I use ELVIS II,the panel write fgen output 10V max.I direct connect fgen(bnc) to scope(ch0),but the scope show vp-p is 63mv.
Anyone can tell me the reason.
(6,938 Views)
Hi, Gan:
Have you ever try to use oscilloscope to verify the signal you have generated is correct?
So that we are more easy to troubleshoot the problem.
AE Yang liu
(6,929 Views)
Check the probes.
(6,508 Views)
yes,really trobule is the probe.
thanks all.
(6,497 Views)
