Actor Framework Discussions
Actor Framework Hands-on: Adding Message Enqueuer Object
Greetings to the AF community,
I have read the white paper and completed Part 1 of the Actor Framework Hands-On using LabVIEW 2014. So far it's really cool.
This is an extremely basic question, but I can't get past it with just google searches and dogged perseverance...
Early in part 2 you have to add a copy of Cooler's enqueuer as an attribute (PDF page 29). The instructions say to open Cooler UI with Events.ctl and then "Add a Message Enqueuer object to the cluster of class private data."
Well, how do you do that? It's not a control, if you select "LabVIEW Object" from the palatte it cannot be configured to a Message Enqueuer object. For that matter, how did they get the Fan Status, Temperature and Pump objects in there to begin with?
Any help greatly appreciated.
Bill
(4,551 Views)
Accepted by topic author billtrib
So, I figured it out eventually. The Message Enqueuer is a class which can be added to a cluster using Select a vi... . Onward and upward...
(4,002 Views)
