Actor Framework Discussions
Asynchronous Calls in the Actor Framework
In this discussiondrjdpowell mentioned the asynchronous calls in the Actor Framework as an example.  When I was looking for all instances of Start Asynchronous Call, I noticed that they are different from each other - Launch Actor Core mentions a workaround for RT and uses non-strict references, while Time-Delayed Send Message does not.
Is this just a change that didn't propagate to all calls, or are there some circumstances where you would intentionally want strict references wired in the Time-Delayed Send Message way?
Screenshots from LabVIEW 2018f1
(7,773 Views)
Accepted by TomOrr0W
Someone pointed that out to me recently. I've made the same fix in LV 2020 for Time-Delayed Message.
(7,260 Views)
I wish I could get the RT bug fixed, but it doesn't affect many VIs, and I haven't been able to get the team to make it a priority since the workaround exists.
(7,255 Views)
What is the RT bug?
(7,235 Views)
@drjdpowell wrote:
What is the RT bug?
Some sort of root loop priority inversion.
(7,227 Views)
(7,222 Views)
