Actor Framework Discussions
Error message during build
I'm using 2020 SP1 now and meet the a similar problem. The project was able to be built well until I turned one sub vi to inline. Then the error 1052 is always there.
As mentioned, I can build the project again after I deselect the 'Modify project ...' option. A strange thing is after that, even I turned the sub vi back to allow debugging, it still has the build error with 'Modify project ...' selected. Have to uncheck this option finally.
Message 11 of 11
(1,004 Views)
