Actor Framework Discussions
Interface for Actors
@DPrida Not fixed as of 2024 Q3.  Why not?
Message 11 of 18
(2,717 Views)
Couldn't get it to work on LV2023 Q3. Not appearing on right click menu.
Any workaround solution?
Thanks.
Message 12 of 18
(2,466 Views)
I want to say that there was a bug with LabVIEW 2023 that broke this and other plugins... which f-patch(if any) are you using?
I can confirm that it doesn't work with with 2023 Q3 (no f-patch). I can try and test with f5 later this weekend.
CLA CLED AF Guild
Message 13 of 18
(2,459 Views)
I also checked the bug fix notes which shows this:
Seems somewhat similar and was also fixed in an f-patch.
CLA CLED AF Guild
Message 14 of 18
(2,454 Views)
I can confirm that in 2023 Q3 f5, the menu appears as it should:
CLA CLED AF Guild
Message 15 of 18
(2,449 Views)
Hi Casey,
Thank you for the info.
Being new to the AF, Interface for Actor helps a lot.
Message 16 of 18
(2,432 Views)
2026Q1 - still not shipped
CLA
Message 17 of 18
(1,146 Views)
We know.
I haven't the words to express the depth of my frustration that we're still mucking about with this CAR, five years on.  When we've had the fix in hand.
Hopefully soon, though.
Message 18 of 18
(1,126 Views)
