Actor Framework Discussions
Interface for Actors
@DPrida Not fixed as of 2024 Q3.  Why not?
Message 11 of 16
(1,289 Views)
Couldn't get it to work on LV2023 Q3. Not appearing on right click menu.
Any workaround solution?
Thanks.
Message 12 of 16
(1,038 Views)
I want to say that there was a bug with LabVIEW 2023 that broke this and other plugins... which f-patch(if any) are you using?
I can confirm that it doesn't work with with 2023 Q3 (no f-patch). I can try and test with f5 later this weekend.
CLA CLED AF Guild
Message 13 of 16
(1,031 Views)
I also checked the bug fix notes which shows this:
Seems somewhat similar and was also fixed in an f-patch.
CLA CLED AF Guild
Message 14 of 16
(1,026 Views)
I can confirm that in 2023 Q3 f5, the menu appears as it should:
CLA CLED AF Guild
Message 15 of 16
(1,021 Views)
Hi Casey,
Thank you for the info.
Being new to the AF, Interface for Actor helps a lot.
Message 16 of 16
(1,004 Views)
