Actor Framework Discussions
Libraries Locked - Possibly connected to the Send-Delayed Time Message still being in use
Hi everyone,
I have a question regarding the workings of Actor Framework, especially since i seem to have managed to trigger some strange behaviour while implementing it.
I am using LV2012 SP1 for this one and unfortunately cannot upgrade the LabVIEW Version for this Project.
So i am calling multiple instance of an Actor in this Example (See attached Code below). I override the Pre Launch Init VI and send a connect message to the particular instance of the Actor.
The Actor goes on to enter the Actor Core.VI and executes the Message "Connect" which looks like this:
So far so good. The Connect.VI goes on to trigger a Time Delayed Message which runs until the actor stops. Now the interesting part - If I introduce a delay into the Connect.VI , let's say a delay of 2 Seconds (look at the above picture for reference) and I run the Code and then stop it - the Libraries in my Project will become locked.
If I do not introduce the Delay, the libraries don't lock. Any Idea why this might be happening?
One more clue - I tried tracking down which VI stays open and it seems that the "Time-Delayed send Message Core.VI" is somehow still in use:
I really don't want to introduce this Bug into a Code a deploy at the customer. Any Ideas about what is happening here would be greatly appreciated.
Siegmund
Message 1 of 8
(5,085 Views)
If your libraries are locked and you close the project, does this dialogue box appear stating there are still some modules running?
Message 2 of 8
(5,053 Views)
Hi Oli,
thank you for your reply. No dialog box appears. I also tried making an Executable  and stopping it and it works normally. After stopping it, there is also no more task in the Windows Task Manager.
So it does appear to be stopping, it just locks the Libraries for some reason.
Message 3 of 8
(5,051 Views)
Accepted by Siegmund
So the actor seems to shut down...
Unfortunately I can only go back as far as LV2013, yet a link which drjdpowell posted some time ago came to my mind:
Quick Tip: Asynchronously launching VIs the right way
Looking at the 2013 implementation, it seems it is done the wrong way there. But I have no clue, why this should happen only with longer delays..
Message 4 of 8
(5,049 Views)
Are you notifying the timed message to stop in stop override?
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
Message 5 of 8
(5,044 Views)
If I'm getting it right, the Time-Delayed Send Message Core.vi should stop at latest when  the Actors Enqueuer get's invalid/ Actor stops.
After trying to send the next time-delayed message to the shutdown Actor, all VIs should stop executing. And libraries should be unlocked
Yet maybe I'm missing something here
Message 6 of 8
(5,040 Views)
Hi Oli,
that did the trick! No more weird behaviour. I will have to test it thoroughly, but at least for now, all seems well. Thank you for your help, you saved me from some future anxiety there 🙂
As Oli wrote, in this particular Example i posted, the timed message stops on it's own, once the "Actors Enqueuer get's invalid".
Message 7 of 8
(5,028 Views)
yes I forgot that it did that.   I guess when I took the class Allen just beat it into to my head to always clean things up in StopCore.  In this case it's not necessary.
Sam Taggart
GCentral
Message 8 of 8
(5,015 Views)
