08-16-2012 01:11 AM
I just modified the Send Template.vi method of the Message Template.lvclass to be compatible with AF 4.1. I have some problems with VIPM to build a new package, so I just upload the source code.
08-16-2012 01:52 AM
Hi Ivano,
What is your problem with VIPM? I also had problem with it when I wanted to make a package for my "Advanced Message Maker". It just hanged up at one VI from "JKI\VI Package Manager\support\ogb.llb". If you have the same problem I can give you the contact at JKI who already tries to solve this problem.
08-27-2012 12:26 AM
For those who have just downloaded the message maker, please make sure you also download the support files for the message maker from https://decibel.ni.com/content/docs/DOC-17168
09-25-2013 10:25 AM
Where should I copy these files?
09-25-2013 10:28 AM
Charles: They replace the files that ship with LV in the "project" subdirectory. There's one file in the root "project" directory and the rest are in the "_Message Maker" subdirectory.
09-25-2013 10:28 AM
Charles: Also, note that these files are for LV 2011. If you're using 2012 or 2013, you don't want to download these.
09-25-2013 10:37 AM
I'm confused, I have installed AF 4.1 for LV2011, with VIPM 2013, and can't find any "_Message Maker" in project directory, nor in the rar archive. Should I just drop all the files in the archive in <lvroot>/project? even the lvproj and lvlib?
09-25-2013 11:03 AM
OK, figured out that I had to install the Message Maker 3.0.6 before. I guess it could be indicated somewhere because I was confused ![]()
Thanks for help!
09-25-2013 11:33 AM
That's the problem with posting the .rar instead of the .vip. The .vip takes care of these questions. 😉 Still, I'm happy when community folks help out by posting files like this, even when they're not quite the right format.
