Actor Framework Discussions
Message Rescripting Broken in Interfaces
Since this is taking so long (why???) I took a look and made another attempt at creating my own fix for the rescripting issue in interfaces which I've attached. I've tested it for standard coupled messages and I don't see any appreciable slowdown at the moment, but I can't guarantee that it covers every use case and is as robust as the original since I can't see that source code.
Anyway... hope this help some people out.
CLA CLED AF Guild
Message 11 of 19
(4,609 Views)
Accepted by topic author justACS
Message 12 of 19
(4,601 Views)
"Unofficial" only in the sense that it isn't NI published. But Allen and I have both vetted each other's work on this... he was the one with the bandwidth today to actually publish it! But these are the fixes that will eventually be in a patch for LabVIEW 2020.
Message 13 of 19
(4,596 Views)
Thanks, Stephen!  I didn't want to speak out of turn...
Message 14 of 19
(4,593 Views)
Awesome! Thanks!
I was going to start in creating a workaround for "Read Class Ancestry Without Loading" next so this definitely saves me some time and allows our team to move forward using interfaces more seamlessly.
CLA CLED AF Guild
Message 15 of 19
(4,580 Views)
Sorry for the delay. This has not been a normal season by any stretch, and we've been slower responding to many issues than in the past.
Message 16 of 19
(4,572 Views)
I have just been bitten by this, so thank you for the fix! (: It works as expected!
Message 17 of 19
(4,520 Views)
I think this issue needs to be re-opened as I've found conditions where the patch doesn't work as intended.
I still saw this issue popping up from time to time and I didn't take the time to really figure out when it happened until just recently, but it seems that while the issue is resolved for normal interfaces, if the interface happens to be contained within a PPL, then the original bug still exists. I'm attaching code that demonstrates what I'm talking about.
Steps to reproduce:
  1. Unzip the attached file and open "Example Actor.lvproj".
  2. Observe that right-clicking the "Example Actor.lvclass" file correctly shows the "Actor Framework" menu.
  3. Change the Example Actor interface inheritance so that it instead inherits from the PPL version of A_Interface (alphabetically before parent class "Parent Actor") as shown below:
  5. Save the Example Actor (it must be saved before settings take effect!) and right click on it again.
  6. Observe that right-click "Actor Framework" menu is now missing.
A patch for this would be much appreciated as I'm in the midst of a large project where we intended to switch to interfaces that are a part of PPLs.
I'm going to open a support request for this as well so try and get more NI eyes on it as well. Speaking of which, did the original patch ever make it to a release? The release notes for any and all versions up until this point don't seem to indicate that is has. Also, is there a CAR associated with the original bug that I can reference in my support request?
CLA CLED AF Guild
Message 18 of 19
(4,375 Views)
Sorry, this was the wrong topic - I'll repost in the correct one.
CLA CLED AF Guild
Message 19 of 19
(4,366 Views)
