Actor Framework Discussions
The "Launch Actor" vi
So the "Launch Actor" vi has been deprecated as of LabVIEW 2014. I really hope it's not removed, because I'm dependent on it in my projects. The "Launch Nested Actor" and "Launch Remote Actor" vi's are too restrictive for the stuff I'm doing.
Lars Melander
Uppsala Database Laboratory, Uppsala University
Message 1 of 22
(8,833 Views)
You can still use it:
PS: Don't mind the back-up I made. It was for some support reasons.
Kind Regards,
Thierry
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 22
(6,056 Views)
Yes, that's why I wrote "deprecated". But it still means it's supposed to be phased out in future versions. I'm hoping that won't happen.
Lars Melander
Message 3 of 22
(6,056 Views)
It will happen in future versions. Probably around LV 2017 or 2018.
What is your use case for "Launch Actor.vi"? Why "too restrictive"? We found that most of the "less restrictive" use cases for Launch Actor.vi were actually bugs in people's code, so I'd be curious to hear yours.
Message 4 of 22
(6,056 Views)
I second the request for keeping the "Launch Actor.vi"
My use case is usually integrating Actors in legacy code. For my current way of doing this, it is necessary to have access to the queue refs. But maybe my approach for this problem is not the best?
Message 5 of 22
(6,056 Views)
I agree, we should keep the launch actor.
My use cases are:
1. Test harnesses: I want a non actor test to launch the actor, send messages and get messages back.
2. Workaround for "code not stopping properly" bug: If I don't keep the launcher open until the root actor has exited the code doesn't stop properly. So I launch the root actor with the deprecated Launch Actor and leave it open until root actor sends last ack.
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
Message 6 of 22
(6,056 Views)
I have a tool set for other users, where each node starts an actor in a network. Because of this, each actor must be started from outside of other actors. I will try to make an example.
Lars Melander
Message 7 of 22
(6,056 Views)
"Launch Actor.vi" is source code...  Any reason why you couldn't keep a copy (or a look-alike/behave-alike version) in your software library, to use even after it's no longer delivered with future versions of LabVIEW?
Message 8 of 22
(6,056 Views)
Test harnesses are much better handled with the test harness VI found in the palettes:
Use Launch Root Actor.vi. That's what handles this case.
This one slipped off my radar. I need to work on it more. It shouldn't be an issue. That'll get fixed before we would pull Launch Actor.vi out. That's not a reason to keep Launch Actor around.
Message 9 of 22
(6,056 Views)
None. It's just that it would be nice if it were updated with the other stuff.
So actor enqueuers must be handled manually from now on? Not saying it's a bad decision, just wondering if that's what you're going for.
Lars Melander
Message 10 of 22
(6,056 Views)
