Actor Framework Discussions
Using inheritance to act on different data in the same way?
@Shiv0921 wrote:
Thank you so much for your replies everyone, apologies for my delay responding.
BertMcMahan in particular, thank you for taking the time to give me pointers on the crash. Crashes are so despair inducing, so I really appreciated your input.  I spent some time this morning implementing the fixes you’ve suggested and also trying some other things and it seems it came down to the start task being put before the register for events? This seems bizarre but moving it reliably caused a crash in non actor code and the example version too so I guess that’s that?
Yep, see my second to last post in that thread above... I had forgotten that in my earlier reply to you, but you get crashes with an empty task registered or if you get the start timing wrong. Permalink to that post in that thread- https://forums.ni.com/t5/LabVIEW/Access-violation-when-registering-for-DAQmx-Event-with-empty/m-p/39...
So yes, it sucks, but don't worry it's not just you 🙂
And once I got those two things fixed my crashes went away completely. Once you get it stable it'll work great.
Message 11 of 11
(639 Views)
