Actor Framework Discussions
Will there be an AF Community "Lunch" at NI Week 2013?
I talked to niACS (Allen). Here's the plan:
At 12:30pm on Tuesday, Allen and I will be at one of the tables outside the cafe to discuss Actor Framework with anyone who shows up. The tables are at the 1st & Trinity corner of the convention center. We'll be there just under an hour to answer questions about AF, look at design proposals and hear your stories of failure and triumph (hopefully more of the latter than the former).
The time gives those of you who want to eat in the cafe a chance to do so first and for Allen and I to grab some off-site grub. I have no idea if the convention center will let you bring your food out of the cafe area. The tables aren't large, so first-come-first-seated.
See you then.
Message 11 of 14
(1,058 Views)
I confess to being a little confused as to the location site.  Am I correct that it is near the 1st & Trinity corner of the Exhibit Area?  [Inside the Exhibit Area, or right outside?]  Looking forward to learning ...
BS
Message 12 of 14
(1,058 Views)
Palazzo area, SW corner of convention center, outside the exhibit area.
Cheers,
Matt Pollock
Message 13 of 14
(1,058 Views)
Ah, graphical communication. Thank you, Matt.
Message 14 of 14
(1,058 Views)
