Actor Framework Discussions
labview actor framework vi icon glyphs locations
Hi
I'm trying to find the location of the glyphs that are automatically added to vi icon when creating accessors for an Actor. I'd like to make this pencil form Write Accessor and the glasses from Read Accessor a bit more white so they don't overlay the text.
Right now I'm changing the visibility of those glyphs by 50% each time I make an accessor which is bit repetitive
(5,274 Views)
bump
(5,234 Views)
Try looking at the Actor Framework Project Provider to see where they are located.  All the vis are unlocked.  I'm willing to bet you will find it somewhere in there.
  • [LabVIEW]\resource\Framework\Providers\MessageMakerProvider
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
(5,229 Views)
Accepted by topic author kdogoms
Allen or AQ can probably provide information, but it seems that you can't find a png because there isn't one.  They appear to use a block diagram constant.  I'm sure you could copy it and write it to png file and then reuse it wherever you want.  See screenshot.
Sam Taggart
GCentral
(5,228 Views)
Hey
Thanks, I was able to change the icon for the Message Send! I wasn't yet able to find Data Member Access vi's. They are not in the message maker. Are they in the same folder? I couldn't find it.
(5,221 Views)
Here are 2 other folders to checkout:
  • [LabVIEW]\resource\Framework\Providers\MessageRescripter
  • [LabVIEW]\resource\Framework\Providers\LVClassLibrary
Sam Taggart
GCentral
(5,216 Views)
Yeah! Thank you.
It was in \resource\Framework\Providers\LVClassLibrary\NewAccessors\MemberVICreation.lvlib
And the vi name was CLSUIP_GetOverlayImageData.vi
(5,205 Views)
