Actor Framework Discussions
project that I am considering converting to AF
I have written a functioning program to control a particle accelerator.  My main UI has 13 separate loops interacting asynchronously with various pieces of equipment.  They pool the results with a bunch of IO on a cRIO.  I want to modularize the code more.  I have used some LVOOP and gone through the training materials.  I have a problem in that I am forced to use LV2010 (long story).  I downloaded the 2010 port but the example is broken...
I would like some help getting started, but I have to balance operating and improving a working system with a complete rework.
I am excited to work with AF as I think it is the perfect fit for my project.
Getting started advice appreciated.
Casey
Casey Lamers
Phoenix, LLC
casey.lamers@phoenixwi.com
CLA, LabVIEW Champion
Check Out the Software Engineering Processes, Architecture, and Design track at NIWeek. 2018 I guarantee you will learn things you can use daily! I will be presenting!
(5,633 Views)
Hi Casey,
I guess I am responsible for the LV2010 version.  It is not an official NI entity.  I will look at the demo again.  It has bee a while.  Can you point me toward what is not working?
Kurt
(4,807 Views)
Casey,
I posted a new version of a demo used at Alliance Day 2011 ported to LV2010.  It is here:
https://decibel.ni.com/content/docs/DOC-21260
This is a very simple demo.  It is not the Cooler demo, but that one is pretty complicated and unless it is extremely important, I prefer not to explore that.
I hope this helps.
And you have come to the right place for help.
Kurt
(4,807 Views)
Here are some shots of what I am seeing.  I can't even get the example open due to something being missing.  I see all of the AF icons, etc in the pallette.  Not sure if this is a problem with loading from the wrong place or if I am missing functional pieces.
Some screen shots:
Casey
Casey Lamers
Phoenix, LLC
(4,807 Views)
Accepted by CaseyLamers1
It appears that omething is messed up with the Actor Framework.lvlib.  I noticed in the dependencies that there is a user.lib folder and ALSO noticed Actor.lvclass is not inside Actor Framework.lvlib.  Here is what my project looks like:
(4,807 Views)
