It is always a pain finding new hardware in NI MAX. You never know the IP Address. It would be great if MAX had the capability to find hardware and configure network settings via ethernet Data-link layer 2. You should be able to identify all NI hardware with your common vendor MAC prefix and communicate network settings. I have seen other companies use this to find and configure their hardware on the network regardless of the ethernet adapter configuration.
