When running a stimulus profile in NI Veristand, there is currently no direct way of enabling/disabling Alarms in real time sequences. It would be great to have this capability for use in real time sequence when you are transitioning a channel value with an initial set of abort limits to a new set of abort limits. With the current set up while transitioning depending on the rate of change of the channel value we may hit the upper or lower limits to an abort condition and trigger a procedure even though we actually meant to change the channel to different value with new channel limits.
