HI
That will be SUPER, if you can add extra option till pop-up menu "Create/duplicate Device as Simulated".
And reversed option (to create Device from simulated one) when you will like to test software with real hardware.
That will be also necessary to do check box to select, which you will like to use. For Tasks purpose, they have to also know which one they have to use.
