Hello everybody.
there is my question\ suggestion - I am using MS 13 - and have to use a lot of bus connections in my design.
when I do connect wire to bus , MS opens for bus entry connection window.
so far so good.
but some how I can see only 6 top lines in that window directly and the rest with scrolling down.
the window could be re sized to show more \all lines, but after I click OK button and have to open that window again - it again appears with 6 top lines shown - it means that window does not remember it was re sized a moment ago.
and it becoming really annoying if I have to connect a lot of wires to the bus.
bus vector connection window does remember resizing instead .
the problem is I can not use vector connections for separate wires (not IC leads)
could it be reconfigured?
could it be fixed in next version please?
thanks a lot
Michael
