Hello
We use Veristand for not only HIL application also TestCell application.
TestCell application often require distributed measurements.
we use Ethercat chassis for single point measurement but I would like to use EthernetDAQ(TSN) for waveform measurement(high sampling rate such as accelerometer, vibration and current measurement).
Currently, EthernetDAQ is not natively supported by Veristand DAQ function, so we need to create custom device for it.
I really appreciated if Ethernet DAQ is officially supported.
