Additional NI Software Idea Exchange
Redacted
MAX - Allow wildcards for batch renaming channels in tasks
Status: New
NI-DAQmx Tasks can frequently have dozens of channels, sometimes hundreds.  Renaming each channel can prove tedious when the format needs to be more complex than rootname_#, indexed from zero.
This change will allow developers to batch rename channels in a more flexible format, saving task setup time.
This idea includes:
1. Using rootname as it is now, allowing for all channels to have a common base name
2. Creating wildcards for naming channels.  Each channel would then have the base name, a changeable separator character if specified, and an incremented number or character(s) specified by the wildcard.  Examples include:
a. Current_[001] = Current_001, Current_002, Current_003...
b. Temp [AA] = Temp AA, Temp AB, Temp AC, ..., Temp BA, etc.
c. [05]_Reactor = 05_Reactor, 06_Reactor, 07_Reactor, etc.
2 Comments
JÞB
Knight of NI
Edit the XML file.  (Yup scary but effective)
crossrulz
Knight of NI
Jeff, I recently did that with Switch Executive configuration files.  Yes, it was scary, but very effective (especially since I couldn't edit inside of MAX due to being on a deployment licensed machine).
