I have hundreds of signals and I want to be able to set a values to them all at once without listing each one individually in every sequence. How do I write to many signals at once? Is there away to assign all the signals to one variable or array of some type and just write to that variable? I did not see such mechanism and NI support says nothing similar exists. Maybe this should be considered.
