I'd like a way to select/deselect dependencies that get sent to the target upon deployment. I understand that all dependencies are necessary for a project to run. However, I deploy one system definition to many targets, and often there are very minor changes that don't need a transfer of all the dependencies which takes time. Also, the fact that the default is to transfer all dependencies means I need to keep every computer updated and sync'd or else a deployment could fail. I'd like the ability to manage which dependencies to transfer and potentially overwrite. Thank you.
