VeriStand natively includes several Action VIs that provide the critical ability to run code on the gateway when a certain action is performed. Most often, this is used for executing code that cannot be run on Real-Time but needs to coincide with an event within VeriStand. This can also be achieved with VeriStand services, but is more complicated. I think that additional Action VIs, specifically ActionVIOnDeploy and ActionVIOnUndeploy would be very useful. And I'm sure there are additional ActionVIs that others would find useful.
