9862 power cable
I want to use a NI9881 CAN module which requires an additional power supply (Vsup pin of the DB9).
Moreover i have a CAN power cable with a positive and a negative terminal in addition to the DB9.
Are this positive and negative terminal, pins for the power supply, or do i have to connect directly the Vsup pin ?
Thank you !
(4,342 Views)
Accepted by topic author vincentlg
If you have a NI power cable such as this one: CAN Cables with Power Terminal
Then the + terminal on the cable is tied to Pin 9 and Vsup.
The - terminal will be tied to Gnd.
Jeff L
(4,296 Views)
The NI CAN Breakout Box is kinda nice in these situations.  It might seem expensive for what is mostly a DB-9 break out, but it has screw terminals for power input, and a DC barrel plug which make powering a CAN bus easier, along with switches for various resistor termination.
http://digital.ni.com/public.nsf/allkb/D3AD3B86FC3A52A386257B2700530419
(4,289 Views)
Thanks a lot ! It's ok 🙂
(4,275 Views)
