NI 9144 with 9862 module
I'm currently working on a NI9144 chassis with a CAN 9862 module.
I wondered if it's really necessary to use an additional power supply for the 9862 module (as indicate in the datasheet) considering i'm using it with the 9144 chassis ? Is it possible to use the module juste with the chassis ?
Thank you !
(4,245 Views)
Accepted by topic author vincentlg
The 9862 requires bus power to provide power to the transceiver. There is no way for it to get it directly from the backplane.
(4,233 Views)
Ok, thank you 🙂
(4,228 Views)
