Adjust Zero on Dnet MFC
So far, so good.  I have gotten fairly handy at running Dnet MFCs.  I open an explicit
message and open an IO then I can set and get parameters and the setpoint.  I can close my application and restart it w/o having to reset the NI-CAN board.  I have just one
more stumbling block...
I want to zero the MFC using the Analog sensor object(x31).  The documentation says this is
done by sending a service 0x4B to instance 1.  I tried doing this using the Write Explicit
Message.vi and I get:
Error -1074388978 occurred at Get DeviceNet Attribute.vi
Possible reason(s):
NI-CAN:  (Hex 0xBFF6200E) You called Read DeviceNet Explicit Message before the response
arrived. Solution: Wait for the Read Avail state prior to calling read; Make sure you call
Write DeviceNet Explicit Message before calling read (every response requires a request).
For sure I am missing something.  I have wired the explicit message handle into Write
Explicit Message.vi.  What am I missing?
Joe
(6,964 Views)
Hey Joe,
First off does your literature state that after sending the the 0x4B service to instance 1, Instance 1 is supposed to return somethingback?  If it isn't supposed to then you are trying to read and nothing is thereto be read.
If we know the after writing to the device we do expect a return message then I would go ahead and try to implement a Wait For State functionality prior to reading (get attribute).  PLease look at the following shipping example (ExplMsgWriteRead.vi)  and notice how they implement aWait for State.vi (you can find the shipping example Here: ...Program Files\National Instruments\LabVIEW 8.6\examples\nidnet\DeviceNet - Basic.ll)
Let us know if this helps!
Charley Dahan
Global Account Manager
(6,949 Views)
Charles,
Thanks.  This is exactly what I ended up doing.  I found that just adding the wait.vi did not do it.  I still had to perform a read after the wait.  Once I did that all was well.  I can now zero the MFC.
Cheers,
Joe
(6,947 Views)
Glad I could Help!
Charley Dahan
(6,931 Views)
