CAN FD+BRS - LabVIEW programming
Hi Jeff,
I revised the code a touch to make it easier to run your experiment. Unfortunately I still get the same error.
My frustration is that I run BM, switch the unit on and it works a treat. I kill BM, run my app, switch the unit on and all I get is errors !!
Is BM written in LabVIEW ?
Andrew
Message 11 of 14
(4,300 Views)
Accepted by RASedden
The bus monitor is written in LabVIEW and is almost identical in structure to the Stream Input example which your application is based on. I was able to reproduce the bus errors using your latest example and think I have figured out the problem.
We should be using the in-memory cluster for CAN FD which is ":can_fd_brs:". Notice there are two colons. Your example only has the first colon. When I add the second colon it works fine.
Since the in-memory constant is missing the colon I would expect to see either an error or some other indication that it isn't right. I will file a bug report to look closer at this behavior to see if it can be improved upon.
Jeff L
Message 12 of 14
(4,294 Views)
Just to confirm that all is now well. I cannot thank you enough for your support - so simple an error but so devastating a result
My CAN FD Terminal is now up and running - onto the decodes !!
Thank you
Andrew
Message 13 of 14
(4,292 Views)
Thanks for this, I would never have figured this out! If anyone needs to set two custom baud rates, this worked for me
Message 14 of 14
(2,800 Views)
