CAN Frame format
Can I have two type of IO in same frame?
I mean can i have 2 DO and 2AO in same TxPDO ?
2bytes for 2DO and other bytes for 2AO?
(6,759 Views)
Yes, you can put whatever you want in the data bytes.
Each data byte is 8 bits so to pack a U16, you will use two data bytes.  You can put 8 DO's in one byte.  Etc....
(6,650 Views)
