I2C interface with 400kHz clock rate
The max clock rate of NI's USB-8451 I2C interface is 250kHz.
Please support my request for an interface with at least 400kHz.
Has anybody used interfaces (with LV driver) from third-party suppliers with a clock rate of 400kHz or higher ?
(6,468 Views)
Hey,
You could use FPGA hardware and this library.
Christian
(6,450 Views)
Hi Christian,
Thank you for your suggestion.
Because I don't use the LV FPGA Module, this is a too expensive solution !
Best regards
(6,445 Views)
