Hi, I am using USB 8476s to communicate to a slave unit in LIN network using LabVIEW7.1. Can anyone tell me how i can send a header file plus 1 byte of data to the slave in a LIN network. or how do i use ldf file. i want to read responses from the slave.
Hi,   I am using USB 8476s to communicate to a slave unit in LIN network. Can anyone tell me how i can send a header frame plus 1 byte of data to the slave in a LIN network. or how do I communictae with slave using LabVIEW7.1.
I want to read responses from the slave. When i tried with labview exapmle programs or even using MAX also, while doing some switching action in my slave, i am getting response as Device inactive with timestamp but there is no data format.
And I have Lin Description File. Can you suggest me how to use ldf file.
I am at customer place and It would be great help from you if you can suggest me at the earliest. Thank you
(6,421 Views)
you may use the LDF Starter Kit to use LDF informations in your application
(6,357 Views)
