CAN: RTSI Pulse on Recieving CAN Frame in Channel API
LabVIEW 7.0, NI-DAQ PCI-6251, NI-CAN:
In LabVIEW, CAN Frame API it is possible to give out a Pulse on RTSI every time a CAN Frame arrives. Is there a possibility to do that in Channel API to? And what about a possibility to log a start trigger in Channel API?
The Problem is that in Frame API i can not read from 2 CAN Objects from the same CAN Network Interface simoultaneously, respectively it is much too slow!
(3,693 Views)
HI KKK-KROK,
Unfortunately there is no technical possibillity yet, to have the same RTSI features for the CHannel API, then for the Frame API.
The best solution for this is to use a two port CAN device to have the Frame API running on the second port.
Dirk W
(3,673 Views)
