using NI-CAN with visual basic .net
I'm using NI CAN 2.3.2 with visual basic . NET.
As there is no driver for VB.NET I use the C functions.
I need help because I didn't succeed to use the function ncReadMult
I declare this function like yhat :
Public Declare Function ncReadMult Lib "Nican" (ByVal ObjHandle As Integer, ByVal SizeofData As Integer, ByRef data() As NCTYPE_CAN_STRUCT, ByRef ActualDataSize As Integer) As Integer
of course I defined the type NCTYPE_CAN_STRUCT but the program stop without error message when this function is called.
Does somebody already use NI-CAN driver with VB .NET?
thank you for your help
JP
(4,487 Views)
Hi JP_V,
Because there is no VB.NET Support right now for NI CAN, it is very unlikely, that someone can help you with this.
I would suggest to try another more C or VB related Forum.
Dirk W
(4,424 Views)
