Debug & release
Hallo,
I'm in trouble with sending CAN-Message to servo-controllers (Lust).  In debug -mode all works fine, but in release it seem's that there some leaks in the message.
I've already added some delays between send-orders, but it doesn't help.
the CAN is a USB-adapter from PEAK.
1. Does CVI make some changes as I include the peak.dll (included in my project) from debug to release?
2. Is there some alternative of using the Delay-Command in windows?.
greetings
F.A.
(4,154 Views)
Hi franky,
i don't know exactly what you mean with the statement "leaks in the message"...
Is there nonsense within the message? If yes then it could be a problem of a variable which isn't initialized! This could be a difference in debug & release mode!
regards, ThSa
(4,107 Views)
Thank you very much
it was indeed an uninitialized Value auf a local part of a struct (which is not displayed as a warning)
greets franky
(4,095 Views)
