CAN bus monitor
Does any use the CAN bus monitor that available in the measurement & automation explorer, to monitor the activities of the buses.
i am sending a message to ECU,and ECU will respond to it. Beside that,i also like to see what other message that ECU is sending.
Or maybe any suggestion to see all the data that available in the bus.
(6,422 Views)
Good day yeoh,
Good to see you are exploring NI-CAN further. Yes the NI-CAN bus monitor is your best bet to see what is traveling across the bus. It will show you all the activity on the bus, not just what you send to your ECU.
If you have questions about getting started I would consult the help document as well as look at the documents in the Developer Zone relating to NI-CAN.
Good luck and Happy New Year,
-Marshall R
(6,412 Views)
