CAN traffic monitoring-NI CAN card
Hi all,
I want to monitor CAN bus activities in a network using PCMCIA high speed CAN card.
Whether it is possible to read the complete data frame including the CRC (even if there is any error) ?
Is it possible using Labview and NI cards?
Can any can help me out.
(3,672 Views)
Hi SajK,
You certainly can monitor the CAN BUS with a PCMCIA CAN card. There is an example VI in LabVIEW called Bus Monitor.vi that will monitor the entire bus for you.
Hope this helps,
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,663 Views)
