01-23-2019 02:06 AM
I need to use CANopen protocol to code my application, but reading the CANopen product description it looks like it doesn't support NI-XNET only the PXI and cRIO modules.
Is it possible to use the CANopen library with the NI-XNET or other NI CAN dongles (USB)?
Cheers,
K.
01-25-2019 08:22 AM
Hello K.,
I believe It is possible to use CANopen for NI-XNET cards through the NI-CAN Compatibility Layer. If the NI-CAN Compatibility Layer is not supported, then you cannot use the CANopen Library.
I hope this helps.
Kind regards,
Ruta
01-28-2019
10:44 AM
- last edited on
07-30-2026
08:43 AM
by
Content Cleaner
The recommended NI products for CANopen communication are NI-9881 or the PXI-8531 module. These are compatible with our NI-Industrial Communications for CANopen driver, which is specially designed for CANopen and allows for quick development and a more-or-less plug-and-play experience.
Since CANopen is an application layer built on top of CAN, it is technically possible to create an CANopen application using NI-XNET hardware and the API. However, in order to implement this, you'd basically be writing your own implementation of CANopen from scratch.
There is also a CANopen library for our legacy NI-CAN hardware, but this is not recommended for new designs as NI-CAN hardware and software is in maintenance mode and is greatly outstripped in functionality and performance by NI-XNET.
This KB is a handy resource on the topic as well.
Hope this helps!
Nick
06-10-2026 04:27 PM
Give our library a try. Maybe that's what you need.
https://www.vipm.io/package/lab_it_studio_lib_xnetcanopen/
