CANopen example code
I am a new CANOPENH user.
Do you have any CANOPEN example in LabVIEW?
(11,140 Views)
Hi Vay,
If you are interested in a CANopen master, you might want to consider using the CANopen LabVIEW Library instead. That way you don't have to deal with many of the CANopen protocol details.
-B2k
(11,131 Views)
Thank you for your advise
I actually have the canopen library which involves all the canopen sub-vi needed.
But what I need would be a simple and complete VI demo using canopen protocole between 2 or more devices (analog or digital input or output...).
Do someone have such a demo?
Thank you.
(11,106 Views)
Hi Vay,
Are you sure you have the new CANopen Library for LabVIEW? (released 2 months ago).
https://www.ni.com/docs/en-US/bundle/ni-industrial-communications-canopen/page/canopenhelp/canopen_h...
If yes see the attached example for writing and reading to a WAGO CANopen Controller for digital and analog I/O.
DirkW
(11,093 Views)
I am interested in trying this example but am having problems with missing VIs.  I have installed the CanOpen library from NI, two port, high speed version.  Many of the VIs needed to run the example are still missing.  Are there additional NI libraries I need or are some missing from the example LLb.
SCReed
(10,949 Views)
The CAN open demo example cannot open completely. Can you send the full DEMO.
Message Edited by suren on 02-09-2007 05:17 AM
(10,426 Views)
If your LabVIEW cannot find some VIs, check the User Lib for the CANopen Library functions. I checked the LLB and i could open the Example without any missing Sub VI.
If that doesn't work, please post the missing VI names.
DirkW
(10,418 Views)
