CCP slave device with cRIO / ECU M&C Toolkit
Hi!
I'm triing to get started with the NI 9853 CAN module and the CompactRIO. I have already read simple CAN massages from a bus and wrote CAN massages.
Finally I want to make a CCP slave device with my cRIO. Is there any code, which already exists?
To my other question: Is the ECU M&C Toolkit interoperable with LV 8.5 and the cRIO 9012?
Thank you for your help!
Message Edited by demo66 on 11-06-2007 11:08 AM
regards,
demo66
(6,901 Views)
Unfortunately there is no official NI ECU MC (CCP)support for cRIO running VxWorks yet. But we  are working to get it ready until end of next year, hopefully.
DirkW
(6,893 Views)
Thank you DirkW for your help!
I found on NI.com a PCMCIA-CAN device. Maybe I'll use this device with the NI ECU MC. Is the Toolkit interoperable with LV RT 8.5 and the PCMCIA device. Is it possible to use the Toolkit as MASTER on the one hand and as SLAVE on the other? If I use the Toolkit as slave, is it possible to use different A2L files?
regards,
demo66
(6,874 Views)
Unfortunately the ECU MC Toolkit only supports the master mode. There is currently no Slave mode support implemented.
DirkW
(6,869 Views)
But does the tool kit work with Labview 8.5?
Colin
(6,510 Views)
Not yet.
We plan to release in Q1, but you could install the LV 8.2 support and copy the necessary folders to your LV 8.5 version. A masscompile would compile them to LV 8.5 then.
DirkW
(6,491 Views)
Thanks Dirk
Colin
(6,471 Views)
