Can I send multiple messages to CAN through an array?
I am very new to this, so bear with me.  I am writing to a CAN bus line, and would like to send multiple messages through the write function in the frame API.  But when i create the control for the data it is just a 1D array.  Am I able to make this a multiple array of messages?
(6,659 Views)
Accepted by Fred420
Hi
For people new to CAN bus, the NI-CAN driver brings examples for nearly every use case. Driver version 2.4 or later has the Write multiple function to write multiple frames at ones.
There is an example available for LabVIEW, CVI and VC/VBasic called CAN Transmit multiple.
DirkW
(6,645 Views)
