Cannot transmit messages in XNET Bus Monitor
Hello, I want to use the XNET Bus Monitor to transmit a message, but the Measurement menu doesn't contain the item "Transmit Frame" like the documentation says it should. I know it works only for CAN, but I do have CAN, the interface is called CAN1...
What do I need to do?
(4,391 Views)
Accepted by Manudelavega
What version of XNET are you using? In the most rescent version (16.1) the functionality in quesiton has been moved to a tab labeled Transmit.
Jeff L
(4,357 Views)
I'm using 15.3.
Edit: OK I just realized that 15.3 also has that Transmit tab!!
(4,353 Views)
